Dji assistant
Here's a question. I've downloaded the the Dji assistant app to my iPad. Is it possible to do imu calibrations on the tablet or do you have to use a computer. Has anyone tried ? Tks
The IMU should be calibrated using DJI GO. Here's an example showing how to do it:
Thanks for the info guys. Another issue , anybody experience compass error In mid flight , I was out in a wide open area Out side temp -2. Hieght 120 meter 1-2 km distance This has been happening quite regular. Wondering if cooler temp at altitude has some affect on compass? Using go 4 app
Had it happen once - flying at about 4000m (up a mountain, not straight from GL) but it was temporary and didn't happen again. It's possible that it was due to poor calibration on the ground (too close to metal objects - may have been rebar under the concrete take off point) but it was a one off so never found out why.
Ya. I never calibrate unless the app says to or I change elevation drastically. Will cooler temps at higher altitude affect the compass also I've been getting vision positioning sensor error as well when the compass error comes up
peoplelogic
