Thanks in advance for any advice. Checked other posts but they have issues that I do not have, like cold or rebooting. PROBLEM: Motors will not start. CONDITIONS: 65 degrees, dry, Battery full, very recent flight-- no issues, same launch location for past 9 months. Connection established between controller and P4P as shown by being able to control camera, video link normal. Normal Nav light display. Unrestricted airspace. No warning or error messages. Just updated software. DESCRIPTION OF EVENTS: Normal pre-flight, battery secure, props secure, etc. Normal boot up, GPS mode--All green-ready to go. Tried to start motors--will not start. Twice reboot controller and drone and remove battery. Still will not start. After many attempt and wiggling sticks around, engines start. Turn off engines normally. Try to start again and again after 3 minutes of playing with control sticks, engines start at normal start controller stick positions. I hover bird, rotate around different flight axes, all is normal. Land and turn off engines normally. Try again to start engines--no go. Remove props and try again--no go. Let drone sit for an hour. Try again. After several attempts, engines start. They start 5 times in a row. Then will not start. Then finally again start for 6 times in a row. I am pleased, then they again fail to start on the 7th attempt. Maybe a control stick contact issue? I know the left stick works in the cut off/start position because it will stop the motors. Not sure about the right stick in the 5 O'clock position.
Any advice would be most appreciated. I can't tell if the issue is the controller, the drone, or something else. Anyone had this issue?
