Difference between Phantom 2 NAZA...
The Phantom 2 Naza is a Naza M V2 that has some of the features disabled and some of the options hard coded. They are otherwise the same.
dklassen said:
What's the difference between the NAZA that comes in the Phantom 2 and the NAZA M V2?
Thx!
There are a few. It uses its own Assistant, and as ianwood said some of the features in Assistant are different from the regular NAZA-M. For one, no X1/X2 gains adjustment. Implementation of separate Phantom and NAZA modes in Assistant. Its firmware also supports the airport no-fly zones ,which the base Naza-M currently does not.
The Phantom NAZA also handles a few P2-specific hardware differences, such as:
- Lock arming without P2 smart battery detected
- Control the status LEDs on the ESCs
- Essentially makes CanBUS support a prerequisite for operation (due to SMB)
And a few other things that are slipping my mind right now.
dklassen said:
Thanks.
So that would basically keep one from pulling the NAZA out and using it on other frames.
Correct (unless you took the P2 battery and mainboard with you).
