- Joined
- Jun 11, 2015
- Messages
- 186
- Reaction score
- 121
It came to my notice that I had a different copy on my iPhone than the one on my iPad of the same version manual. So, after a conversion and document comparison, here are the changes to the P3P User Guide dated 6/1 from its previous version (I wish they at least indicate manual rev#s so we can keep track of changes better). So no one else needs to compare and contrast, all of the changes the comparison program found are below. Top picture is current manual, bottom is previous. Green underline indicates additions, red strikethrough indicates deletions.
Failsafe RTH
While the previous version stated only that during a Failsafe RTH, if you moved a stick, it would stop ascending...the new version clarifies 1) if you are within 20M radius of your Homepoint, it will immediately land. 2) provided you are 20M above your Homepoint and you move your sticks, it will stop ascending, and move directly to your Homepoint (rather then immediately stoping ascent regardless of AGL). 3) A weak GPS signal will prevent the aircraft reaching its Homepoint.
Dynamic Homepoint
The previous manual indicated that when setting a dynamic Homepoint, your Homepoint will be set to your controller, and update itself on a regular interval. This is not the observed behavior, and the manual has been updated. You must reset the Homepoint again manually if you want the Homepoint updated again if you've moved the location of the controller.
Restricted Areas
The new manual clarifies that a warning message will be displayed when youre within .062 miles or 100m of a restricted zone. The previous version state .6 miles and 1Km.
Failsafe RTH
Dynamic Homepoint
Restricted Areas
