You must be flying very high if it's an issue for you.Is there any way to incresse decent speed on p3p. I find it restricts my flight time greatly
Descent speed is 3 m/sec and you're stuck with it unless you want to use the CSC method for fast descents.
However that has the undesirable side effect of considerably reducing your subsequent flight times .
You can do this. Motors only shut off when drone stops moving down.In descent can you pull left stick fully down? Or will this shut off motors? I would like to descend a little faster also but too afraid to use full stick down.
Thanks! this will help me descent a bit faster.You can do this. Motors only shut off when drone stops moving down.
Seems to descend faster isn't the same as descends faster.It might just be me, but if I roll and pitch while descending it seems to descend faster than just coming down vertically.
