Deliver Payload to Vertical Pole
So there is a lot of information for carrying and dropping a payload but nearly zero information for delivering a payload to a vertical surface.
My application is to deliver a 450g payload to a vertical antenna tower . The payload has high power magnets to attach it to the tower however the payload must be carried away from the center of gravity and beyond the propellers and propeller wash. In theory the payload could be mounted to a rod extending out from the drone both fore and aft. Then a counter balance applied to the rod opposite of the of the payload, however the counterbalance would have to either be released or move after delivery of the payload to correct the change in center of gravity.
I would like to hear other ideas if anyone has attempted anything like this?
What drone has the capability to carry a load of 900+kg? Load + counterweight + extension for load and counterweight. This sounds more like a job for helicopter as this is nearing a ton to be lifted to the tower.
GRAMS not Kilograms....sorry basically 2lbs of combined payload and counterbalance.
Reactions: Harleydude
You would also have to be careful that the magnets aren't going to interfere with the drone's compass.
Unfortunately the compass cannot handle the magnets so the compass has to be disabled, certainly not optimal operation.
You could use a detachable arm system with a quick-release mechanism. Mount the payload on a rod extending forward, balanced with a small counterweight at the rear. After attaching the payload to the tower, the rear counterweight could be released automatically (e.g., with a servo or magnetic latch) to rebalance the drone mid-flight. Alternatively, consider a sliding counterweight that shifts after payload delivery to restore the center of gravity.:)
