Decrypt any DJI flight log with Flight Reader
msinger
Approved Vendor
Harrisburg, PA (US)
Website
phantomhelp.com
Since the release of DJI Fly 1.2.2 and 3rd party applications using DJI SDK 2.4.13, DJI's flight logs are being protected by an encryption scheme that hasn't been shared with most of the developers who created DJI log viewers. That caused most of the commonly used log viewers (like my free online log viewer) to be rendered useless for newer DJI apps and the last several consumer drones released by DJI.
A recent partnership with DJI allowed me access to the DJI API — which several other partners (like Airdata) are using today to decrypt the new flight log format. After a few months of development and testing, I'm happy to announce Flight Reader (my offline log viewer) is now able to process flight logs created by any version of DJI GO, DJI Fly, or other apps using the DJI SDK.
Never heard of Flight Reader? Here are some of its benefits:
  • No monthly fee
  • Privately process & store your flight logs offline
  • View an unlimited number of flight logs
  • Customize the logs & reports to best meet your needs
See more details about Flight Reader here.
TLDR: You can use Flight Reader to process and view your encrypted TXT flight logs offline.
Are you going to process other sources in the future such as Pix4Dmapper logs?
Flight Reader is currently able to process flight logs from DJI, Litchi, and Map Pilot. I'm interested in adding other flight log formats suggested by Flight Reader users.
Reactions: eshafer15
  • No monthly fee
Will there be an Mac OS version ?
A new version of Flight Reader is available. Release 1.2.28 includes the following changes:
  • Added missing model names for the Matrice 210 RTK V2 and MG-1P drones
  • Updated times to display two hundredths of a second
See the release notes on the Flight Reader download page for a complete list of changes.
A new version of Flight Reader is available. Release 1.2.30 includes the following changes:
  • Added a new feature that allows flight logs to be processed via the command line and (optionally) copy the output to any location
A new version of Flight Reader is available. Release 1.2.31 includes the following changes:
  • Added incomplete records that sometimes appear at the end of DJI TXT flight logs. While these records are often missing key data, the data they expose could be useful for troubleshooting purposes.
A new version of Flight Reader is available. Release 1.3.1 includes the following changes:
  • Added a “Photos” column to the main window to show the embedded snapshot images available within many DJI TXT flight logs. The full size snapshot images are available in the log folder Flight Reader generates when processing a flight log.
A new version of Flight Reader is available. Release 1.3.3 includes the following changes:
  • The battery data could not be decrypted in some flight logs. That failure was causing Flight Reader to generate empty log and KML files.
  • Resolved an issue that sometimes caused the max speed to display as infinite.
A new version of Flight Reader is available. Release 1.3.11 includes the following changes:
  • Added "RC.downlinkSignal" and "RC.uplinkSignal" for Litchi flight logs.
  • Correctly converted the "BATTERY.current [A]" value for Litchi flight logs.
  • Made changes to allow Litchi and other CSV flight logs to be properly loaded when running Flight Reader in a location outside of the US.
Reactions: Droneted
.. because all humans should already know about this? :)
More like wondering if a real person could come up with such a strange and inane comment as the one above...😏
"Great post, I had never seen this type of amazing post ever."
And if I am wrong Daisy, and its just a language issue, my apologies...
Typically to be followed up by random posts with links.
A new version of Flight Reader is available. Release 1.3.14 includes the following changes:
  • Added support for processing Mini 3 Pro flight logs.
  • Added ability to process Drone Harmony CSV flight logs.
  • Allow logs to be opened by right clicking and choosing “Open With” → “Flight Reader”.
A new version of Flight Reader is available. Release 1.3.15 includes the following changes:
  • Added a description for battery statuses that were displaying "Other" in the "Battery.status" column.
  • "Forced Landing" was incorrectly being displayed in the "OSD.flycState" column in cases where the state was "Confirm Landing".
  • The map view was sometimes displaying data in the wrong columns for the first several lines of Mini 3 Pro flight logs.
A new version of Flight Reader is available. Release 1.3.17 includes the following changes:
  • Added support for processing Matrice 30T flight logs.
  • When installing Flight Reader, the WebView2 Runtime will only be installed if a compatible version is not already installed.
  • When processing flight logs using the "process-log" command line switch, the HTML and battery CSV files will also be copied to the destination folder.
A new version of Flight Reader is available. Release 1.3.23 includes the following changes:
  • Made improvements to fix scaling issues when using Windows display scale settings over 100%.
  • Corrected a few issues preventing some DJI GS Pro flight logs from being processed.
  • Added a few requested enhancements.
