DBS Mod vs. ITE's mount for ITELite Panel
I care!.. especially how it is folded down.. would love to see if it still fits in the hard case backpack
Not using the backpack, got the aluminum hard case for the Phantom 2 by mistake, so I carved out the foam until it fit like I wanted. (saved about $100 bucks)
I used the bracket and hardware that came with the DBS 01, just worked it a bit. Before you say anything about the Velcro, I've used 2 different clamp mounts, and this is way more reliable. Makes the antenna serve 2 purposes. And I can adjust the angle of the antenna easily.
Here's mine, just finished it less than an hour ago. This is the ITE-DBS01_V.1 from ITELite's website but I made my own mount on the 3D printer today at work so I could pitch the antenna up or down. Turned out pretty good.
Oh man...that's super cool! If you sell them, I'll buy one!
I've got the ITElite DBS 01, bought it for $80 on ebay. Had to buy longer cables for my P3S internals. More than doubled my range, I get over a mile now.
I modified the mount so it flips to rest on the bottom of the controller for storage. (Also serves to support my tablet)
I'll post pics when I get home, if anyone cares...
Techop, I care. Please post your mod!!! I haven't ordered one yet but I like to get ideas.
Thanks!
OK, I definitley want one of those mounts!
Okay...I just installed the antenna with the dbs mods mount and so far I'm happy with it. Will post pictures later.
Very nice Tony
Finished mine couple weeks ago.
I have the DBS's mount and works very well
Also while I was in there, I removed the throttle lock.
Sorta OT..FYI you can fix this also without removing it . Did this to mine and also back with my P2 TX like this .Just seemed easier
and can push it down later if you want .Mod.jpg P2 TX but same as in P3S .
Smart move with the better insulated cables and looks good Tony :)
and can push it down later if you want .View attachment 42655 P2 TX but same as in P3S .
Thanks Dirkclod! I ordered them from Tony at FPVLR :)
Reactions: dirkclod
Where I got mine also and did get better results with them than those thin black ones .
Gotta find another place to get them though as the shipping is as much as the cables :rolleyes:
You did put a little hot glue over those connecters after that picture was took didn't you.
If ya didn't if you see any issue's that is where I would check first .
I know you know that but through it in for others ;)
