Dark photos/shots
Inland Empire
Recently my P4RTK has been shooting a few dark shots. It's not consistence as out of 150 shots taken maybe 10-12 are darker and it happens near the end of the flight. Anyone else had such an issue?
Hum, your links aren't working,
If I copy this into a browser.
[email protected]
UBoob says I'm trying to sign on to your account?
BTW, I assume most know, Google, has owned YouTube at least 5 years?
Rod ..
haven't seen images;
dominating bright whites can underexpose images...
dominating blacks & shadows can overexpose images...
in both cases, one would compensate before exposing,,,
Reactions: jaja6009
As always, use the KISS method, I switched out SD card. The results were back to normal, must have been some form of corruption on the SD card starting to developed as I never share cards between my drones. This keeps my hopes up for still using my Phantom 4 RTK for small projects (75-100 acres) or less, saving the wear on the Mavic 3 Enterprises for the big jobs.
Thanks for the update!
Did you ever reformat that card?
I have learned they actually get old.
Even a Format won't fix them.
Rod ..
Rod ..
I normally never format a card, unless I do it in the drone itself. After d/l data I just delete the files, but as you said the card may have been getting old.
Reactions: RodPad
Glad you figured it out. And maybe this will help others in the future with the same problem.
I have found consistent success with the P4RTK by using Shutter Priority, adjust shutter speed according to sunlight (1000 to 1600), EV 0, ISO 100 or 200 and locked, and I know I am in the sweet spot when my aperture is between 3000 and 5000 as adjusted by the items in the scene (dark or light).
When I use and get the above my images are perfect (sharp, focussed and neither over or under exposed.)
For my personal fleet I use the P4RTK since it meets my needs.
At work we just got a Mavic 3 Enterprise, it goes for its maiden flight next week. I find the P4RTK superior in one big way, its size. I can keep it VLOS much easier. Also it is not beyond possibility to get a waiver to use its unique drone swarm for mapping if you have multiple aircraft.
I just processed a 3D model for a building inspection and in Agisoft it is photorealistic and actually very good.
Reactions: Recoveryone
Yeah, I didn't believe they could actually start failing over use.
This conversation came up related to a SSD drive.
Reformatting?
To me it cleans up, back in the day the FAT tables.
Maybe another member can add or correct my statement. 👌
Rod ..
