Hello - apologies for the cross post but I was hoping to get some feedback to try tonight.
Currently I'm having a problem getting the motors to start when executing a CSC. This has actually occurred twice in the last 3 weeks I've had my V2+ and the symptom is the same - on CSC typically just the camera rotates slightly but nothing else.
The last time this occurred I noticed in the RC Assistant that the TX signal was stuck all the way to the left. After trying to calibrate the led on the controller went a yellow / green and stayed that way. All other sticks combinations would register - everything that is except the thrust axis.
I "fixed' this last time by reloading the firmware on the controller, calibrating in the RC assistant as well as the Phantom assistant and that resolved things.
That said it happened again yesterday after a day of flying prior - no warning - except this time reloading the firmware isn't working and I'm getting no motion on the TX (vertical) axis on on the left stick (in Mode 2). Calibration simply doesn't work and I am not getting a signal in either the RC assistant or the Phantom.
I'm highly doubting that the controller is the problem seeing as this has happened before and a hardware issue would generally be consistently "broken". I'm leaning towards a software issue / calibration issue but I do have a few questions.
1.) Has anyone else seen this?
2.) Is there a way to avoid this in future?
3.) Does anyone have suggestions on how to fix as I'm grounded at this point!
One other odd thing I'll throw to the Gurus on Phantompilots that may be related is that I did insert an SD card while the phantom was on (by mistake) the evening prior. I'm not sure if this is related but mention it given that the gimbal / camera are related to the controller and motion - as well as the fact that the camera is the only thing that moves slightly on CSC (as it did the last time I resolved it).
Thanks in advance for any and all suggestions (or if this is in fact a noob question!).
Andrew
Andrew
