Crystal Sky Adapter
CS3
Adapter to controller.
Hey all, I’ve developed a Crystal Sky adapter that is relatively inexpensive very sturdy and doubles as a battery protector. This unit uses the same clips and top pressure anchor as if you were mounting your smart phone onto the controller. We’ve been shipping these locally for about a month now with great reviews and feed back.
We are always looking for feed back on our products and up to this point all feed back has been positive.
The CS3 adapter takes advantage of an interference / geometric fit around the battery of the CSM. While still allowing the battery to be inserted and easily removed from the CSM while encased in the adapter. The engineering of the CS3 adapter will not allow the monitor to become dislodged. In fact the design tolerance of the CS3 Adapter is such that if the alignment of the battery to the CS3 Adapter is not perfect the adapter simply will not mount. For your piece of mind we test all CS3 adapters for coupling prior to shipping.
We have been using this design for a few months now and have not had a single coupling failure. The interference and geometry of the fit of the adapter allows for confidant use.
I personally fly every day and use our adapter!
Contact me at
[email protected]
for details
Dan
