Convert P2V+ busted gimble into fixed camera?
Anyone tried converting a broken gimble assembly to a fixed mount? Would like to use the camera even without stabilization but would need to kill power to the gimble motors at the very least. Not ready to drop $700 on another fragile DJI gimble. Any ideas?
Techvt, I think you can find your answer on this thread - lot's to read but it's there...
http://www.rcgroups.com/forums/showthread.php?t=2213815&page=3
Also, you could just disconnect the cables one at a time to see which stops the gimbal from working. I'm pretty sure it's not the 6 pin cable but one of the other two...
You can unplug the ribbon cable from the roll & pitch motors. I'm not sure how the yaw motor would behave with this done, but this might get you what you want.
Another option would be to replace the P2V+ gimbal/camera with another, more durable variety. With a simple rewiring job (moving a few plugs), you can retain most of the original features.
EstebanP4+
