Confirming Stock Range of Phantom 1.1.1 with Immersion 60mw
Hello all fellow Phantom Pilots.
I have my mini iOSD arriving today, so I am really looking forward to installing it on my Phantom v1.1.1.
Up until now, I have been FPV'ing but saying close to get use to it. However, with the iOSD, I will not have the data on distance, battery voltage, etc to fly more informed.
Can someone please confirm the range that I should not exceed with the stock Radio and the Immersion vTx 600mw?
Thanks!!
Re: Confirming Stock Range of Phantom 1.1.1 with Immersion 6
Thanks!!
Watch for the "FS" in the lower left corner on your IOSD video. That's when it turns around and heads home.
I've had mine out to over a mile. Pretty sure it will go further from others I've seen on here.
Thanks for the tip. I would like to avoid it going into FS, but a mile or is plenty.
Depending on your flight environment (obstacles, reflections, rf saturation), it's pretty common to get 800m - 1200m, give or take. Sometimes you get a bit less, sometimes you can get a bit more.
I forgot to mention I have Fatshark/Spironet antennas on the Tx on the vehicle and a Spironet/Patch on the monitor. Makes a big difference
Sweet. I have the same antennas!!
Here is a very cheap FPV setup, you can get 1km+ range with this setup, its a nice start to FPV.
And if you use a directional antenna on the receiver you could go above 2km.
Boscam TS351: http://j.mp/1iwjZzR
Boscam TS353 400mw: http://j.mp/1gJ6t7s
Boscam receiver RC305 5.8Ghz: http://j.mp/1cRoJjy
RC305 + TS353 combo: http://j.mp/1iuhzQ6
Antennas (circular polarized)
cloverleaf antenna to rx: http://j.mp/1arIRFU
Cloverleaf antenna to tx: http://j.mp/1dG8kbW
7" LCD: http://j.mp/1d7kwsr
Boscam 7" RX-LCD5802 5.8GHz Diversity Receiver: http://j.mp/1lZuham
LCD Battery Charger: http://j.mp/1h3CreQ
Just to show how well this setup works here is a video i found on youtube (4.6 km on minute 8:14), in the description is the setup used, and you can read RC305 and TS351, just like this setup:
http://www.youtube.com/watch?v=7pkYzuNXp_c
Wow, furthest out today 1600m, about 1.1 mi. Video was fine and still had control. Then I could not fly any further no matter how much I pushed the stick forward. That's when I realized I must be hitting the pre programmed range limit. I think you can adjust that, need to plug into assistant tonight.
DonT
