Compass error - switching to ATTI-mode
Hi!
I've have had a problem that if I turn the direction of the P34K (default left-hand controller), it will exit P-GPS mode and switch to P-ATTI mode. It happens immediately if I turn the P34K more than 10 degrees. It will cause flyaway. The P-GPS might return after 1 minute when I have kept the aircraft steady.
The problem does not appear if if I move it forwards, backwards, climb or descent. It immediately exits P-GPS if I turn the direction using the left-hand contoller of the P34K.
My unit was sent back to DJI. They claimed that the problem is fixed. I have calibrated compass in middle of a law covered by the ice where are no metals objects or any structures. I have calibrated it in a field. However this problem still keeps appearing every time.
My question is, is that normal behaviour of P34K and should I tolerate it? I would not want to send it back to DJI because it took 2 months them to investigate the issue. I just bought it from a shop and they sent it immediately to repair.
