compass calibration
Doesn't matter what your flying.
General info, help.
Rod ..
Reactions: Mark The Droner
Can not calibrate compass. Have moved away from possible interference no luck
Any more details?
Why are you wanting to calibrate the compass?
If you are trying and it always fails, you should have a look at the Sensors page in your app settings here:
What you are looking for is the numbers in that third line down.
If you have numbers, that's good, but if you don't that's indicating that the compass sensor is busted or disconnected.
When that happens, you get a compass calibration warning and the compass won't ever calibrate.
@Larry Janke
Your getting help from people that are smarted than I.
From only other post you done.
It appears that this unit you have, you have never seen it work before?
Need more details. :) 👌
Rod ..
