I have a DieHard deep cycle 12V battery, a 1000W pure sine wave inverter (This one is "Power Tech On", but there are a lot of them on Amazon). I have a battery isolator solenoid that is connected to my van's battery. It connects the two batteries when the ignition is on, otherwise they are isolated, so I can't run down the van battery accidentally. The inverter powers a Venom P4 Professional battery charger, which can charge four P4 batteries simultaneously (400W total). Assuming a 0.9 efficiency for the inverter and 0.9 efficiency for the charger = 0.81, this would take 500W power from the battery, or 41 Amps. The DieHard battery is 72Ah so theoretically I should be able to charge all four P4 batteries simultaneously for (72/41) = 1.75 hrs. Of course after that, just start the van and charge the system from the alternator. Great for charging P4's in the field, then charging the 12V battery while driving to the next gig. No noisy generator required. I also bought a Black and Decker 6A automatic battery charger to charge the DieHard from 110V if I need to. This rig cost me roughly $450 (battery, inverter, isolator, two circuit breakers, wiring, some scrap 2x4's and plywood, screws, bungee cords, marine batttery box, 110VAC automatic charger).
By the way, the Venom charger is a phenomenal piece of kit, and really speeds up charging. The only problem is you have to move the P4 battery contacts slightly with a wide bladed screwdriver to get them to fit in the charger, but the batteries still fit OK into the Phantom after that. I paid $460 for mine, but they are phasing them out, and now have them on sale for $230:
DJI Phantom 4 Venom Pro Charger 4-Channel 100W Rapid Speed Battery Charger
I would buy one quickly, before they sell out.
I asked customer support about the P4 battery contacts, and he said they are are not going to retool this charger to get a better battery fit, and are discontinuing the chargers (maybe because they are tired of telling customers how to make the batteries fit?). Anyway, once you adjust the P4 battery contacts, the charger runs like a champ, no issues.
