Can't shoot RAW on Phantom 2 Vision
Hi guys, for some reason I cannot shoot RAW with my Phantom 2 Vision. I read a previous post where the fix was to update the firmware, so I tried that, along with different SD cards and different programs on my MAC before posting - but am getting nowhere... does anyone have any thoughts or fixes?
Thanks so much, Charlie
Which version of the camera firmware you have?
cfbrooks said:
I just upgraded to the firmware to version 3.04
You need to upgrade the FC200 firmware. The current version is 1.1.9. http://download.dji-innovations.com/dow ... v1.1.9.zip Inclosed in the zip file is upgrade procedure:
Major New Features:
Thank you for your patience !
The latest camera firmware v1.1.9 now supports Adobe DNG RAW format capturing. It also records the GPS location and relative attitude in the metadata of the Adobe DNG RAW file. DJI will keep working hard on improving the quality of the RAW file and providing the best aerial photography solution to our customers. Thank you for your constant support !
Update Procedures:
Follow the below instructions to update your firmware.
a) Download the latest camera firmware and unzip it.
b) Get a clean Micro-SD card (less than or equals to 32GB), and copy the °∞firmware.bin°± file to the root folder of the Micro-SD card.
c) Make sure the camera is turned off, and insert the Micro-SD card into the camera before turning it on.
d) Turn on the camera.
e) The firmware update will begin automatically. A yellow flashing LED on the camera indicates that the camera is updating.
f) When the yellow flashing disappears, the firmware has been updated. After a successful update, the °∞firmware.bin°± file°Øs name will change to °∞firmware.bin.bak00°±. This file on the card can now be deleted.
Special Notes:
a) During the update, do not turn off the camera or take out the Micro-SD card. This may prevent your camera from switching on and will need a factory reset.
b) A fast red flashing LED on the camera after the update means the update has failed. Please try again.
c) You need to use the latest DJI Vision App (iOS App: v1.0.32; Android App: v1.0.38).
What to do with a ZIP file you ask? http://bit.ly/A1VJdZ (use 7zip: http://www.7-zip.org/)
thedrinklabsus
