can't get Grould station to work
HELP! I do everything right, I think but when I hit "go", the drone tries to lift off and promptly turns over and does a face plant. I set the waypoints on the map while I have internet access, program in 3 waypoints , the height and speed but it keeps crashing on take off.
What am I doing wrong?
Thanks,
Is your first waypoint set downrange somewhere? If so, set one directly above your take-off point, at some height closer to that of what is currently your first waypoint. Or, manually launch first and get up to altitude before hitting go and sending it on its way.
bcass1 said:
Ok I'll try both. My first waypoint was down range from my starting point.
Yep, the Phantom was trying to take the shortest path to that waypoint straight from the launch point, before it even had enough lift to get all the way off the ground.
Ok I made it work this time. I lifted off and then hit the go button and it flew it's mission. I have to say it was a bit scary at the end. I couldn't gain control even after hitting the cancel mission button. finally I was able to recover control and land.
intertronixlabel
