Cant connect my dron with pc
Hello,
Last weekend i try to connect my lap top (using the latest of firmware) but nothing. I try to connect remove controller and the dron. Both of them wont connect.
That eas in win 7.
If i have time ill try with my iMac.
I wanna see specifications of batteries (i have 2) and to check everything.
Reactions: David Bruce Kerr
I copied this from a previous post:
You need to Disable driver signature enforcement. To do this you need to:
First off you need to enable installation of unsigned drivers.
Hold down the SHIFT key while you click Restart.
Once your computer has rebooted you will be able to choose the Troubleshoot option.
Then head into Advanced options.
Then Startup Settings.
“Disable driver signature enforcement”. To choose the setting, You will need to press the F7 key.
Once your computer Starts back up you have to manually install the driver. Plug your dji device into the computer "supply power from a battery" and open device manager.
You should see your device listed under ports as "USB Serial Device (COM##)".
Now right click that device and click properties and under the Drivers Tab Click Update Driver.
Then Click the "Have Disk..." Button.
Then Browse to this directory
C:\Program Files (x86)\DJI Product\DJI driver2.02\source64
And Select The Dji Driver "dji_vcom_driver11.inf" and hit Open then OK
Hit Next and allow windows to install the driver software anyway.
This worked for me and I have windows 8.1. Good Luck!
Hello, it will be easy if i try to use Mac?
I dont know if the last owner have registration but I wanna make one to chceck the usege of the dron.
Ill try later today or tomorrow and ill let you know.
Thanks for your post David. I was about to give up.
hcashmore11
