Can't calibrate - Too much magmatic interference
Central New Jersey
On vacation with P3 and I could not calibrate because of error message of to much interference in open park and 95% empty parking lot. Any thoughts.
Move around and find somewhere away from steel.
Your Phantom is telling you that it's detecting a magnetic influence greater than what it expects due to the earth's magnetic field.
That means there's something else nearby magnetic ... like reinforcing steel in concrete, or a buried pipe or you might be too close to a car etc.
Thanks for replies I am getting this message often at different locations where I try to fly. What is the down side?
Hi Mike, welcome to the forum!
Make sure you don't have metal in your pockets. That can also throw off a calibration. If you do get a compass error in flight, you can switch to ATTI mode to stop an out of control phantom. Land as soon as possible and re-calibrate. The compass mod should be around 1500.
I found out that when I do the compass calibration I cannot wear my Apple Watch and because it causes a calibration error. I suspect that the band I have on the watch is causing the problem because of the magnetic latch that is on the watch.
Reactions: Techcop50
robvalduga
