Can not update bird or batteries
SOLVED
I get long Beeeeep, no solid green light. Tried format card, etc.
Tried multiple times to restart bird after long beep
DJI Go states still needs update
Result: Success.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Failed.
Result: Failed.
Packet: P3X_FW_V01.03.0020.bin
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Was this with the 16gig sd card that came with it? If not, try a different sd card
yes it was the card that came in it. Brand new not yet even flown.
See if this helps...
  • P3X_FW_LOG_AB.txt
Tried different card, still no luck.
That's normal if the upgrade process is stopped just let it beep takes about a half hour or so of the painful noise
Even after the solid red light on the gimbal and solid beep sound? I understood that was a sign of failure.
1 day old never flown. I took it back to the shop/dealer I purchased it from and after they said diagnosed it had a hardware issue. Swapped it for another and said they would deal with dji on that unit. Thank God for good dealers.. :)
Thank you 1UAS in Riverdale, Maryland.
Reactions: Reed L
src72
