Can not update bird or batteries
Discussion in 'Pro/Adv Discussion' started by aka1ceman, Nov 23, 2015.
  1. aka1ceman
    SOLVED
    I get long Beeeeep, no solid green light. Tried format card, etc.
    Tried multiple times to restart bird after long beep
    DJI Go states still needs update
    Result: Success.
    ========== 2014.01.01 00:00:12 remo-con disconnect======
    Packet: P3X_FW_V01.04.0010.bin
    Upgrading ...
    Result: Failed.
    Reboot the aircraft and try to upgrade the firmware again.
    Result: Failed.
    Result: Failed.
    Packet: P3X_FW_V01.03.0020.bin
    Result: Failed.
    Result: Failed.
    Result: Failed.
    Result: Failed.
    #1 aka1ceman, Nov 23, 2015
  2. Reed L
    Alta, Ca.
    Was this with the 16gig sd card that came with it? If not, try a different sd card
  3. aka1ceman
    yes it was the card that came in it. Brand new not yet even flown.
  4. aka1ceman
    See if this helps...
  5. aka1ceman
    Tried different card, still no luck.
  6. advhawk
    Seaford, NY, USA
    That's normal if the upgrade process is stopped just let it beep takes about a half hour or so of the painful noise
  7. aka1ceman
    Even after the solid red light on the gimbal and solid beep sound? I understood that was a sign of failure.
  8. barefootbeachcombing
    US
    Have you checked the status text file on the card?
  9. aka1ceman
    See P3x file above... I attached it here to see if someone can make tails from it.
  10. aka1ceman
    1 day old never flown. I took it back to the shop/dealer I purchased it from and after they said diagnosed it had a hardware issue. Swapped it for another and said they would deal with dji on that unit. Thank God for good dealers.. :)
    Thank you 1UAS in Riverdale, Maryland.
    #10 aka1ceman, Nov 24, 2015
    Reed L likes this.
Similar Threads - update bird batteries Forum Date
Can't get controller and bird to connect. Just updated. Any ideas? Pro/Adv Discussion Thursday at 8:02 PM
Update to My Repair - "motor replacement" = New Bird Phantom 4 Discussion Dec 28, 2016
Future firmware update issues? Bird yes RC no. Thoughts on "GEO" Standard/4k Discussion Jul 9, 2016
Updated DJI Go. Do I need to update my bird? Pro/Adv Discussion Dec 9, 2015
Advanced Done the dreaded firmware update, bird now dead Phantom 3 Help Sep 19, 2015
