Can I install P3P camera on P3A body?
Hi,
I recently bought a P3A. It works great but the quality of the realtime downlink video is very poor due to the high compression rate.
I am wondering if I can replace my P3A camera with a P3P camera to get better downlink video.
Here is a link for the camera I am considering:
[WIKI]http://www.bhphotovideo.com/c/product/1148801-REG/dji_cp_pt_000191_4k_camera_for_phantom.html[/WIKI]
Your link didn't work but lots of people have changed to the pro camera on the advanced.
Thank you guys!
I wonder what would the DJI app list the drone as after the camera replacement, a pro or advanced?
The link is for "DJI 4K Camera for Phantom 3 Professional Quadcopter" from bhphotovideo.com. They are selling the P3P camera for $350.
just make sure you do a firmware upgrade with a P3P bin file after you install Pro camera on your advanced, so you will have to use a P3X...bin file instead of P3S...bin that you would with advanced gimbal/camera installed otherwise the fan on the Pro gimbal won't kick in.
Reactions: Reed L
It should show the Pro since you'll be running Pro firmware.
I'm going to light the fuse ... I .... Just ..... Can't ..... resist.
It won't increase you downlink bitrate ......
There. I said it!
There. I said it!
The 2-Mbps bitrate is the reason I want to upgrade. I don't care too much about 4K. But if I can't get better downlink bitrate, then... oh, well.
I thought the upgrade will increase the bitrate. Anyone who have done the camera replacement can testify?
Here is a picture of the P3P camera unit I am thinking about buying.
[file]P3P Camera CP.PT.000191|none[/file]
The upgrade will increase the downlink bitrate as noted earlier, just don't forget to use the P3P firmware as I also noted in my earlier post. Check the classifieds. There are often camera/gimbal combos for sale there. Or reach out to @Ted4797 (camera specialist) or @hunch (phantom repair). They often have a combo unit available for sale and they are regulars here so maybe help them out first if you are so inclined.
In one of the other similar threads, a wise man (@msinger) once answered the question, "Will that also give me the better 10Mbps over the advance 2mbps," by replying, "Yes. After swapping the camera/gimbal and installing the Phantom 3 Professional firmware, you will have a Phantom 3 Professional (minus the badges that say it's an Advanced)." You might also consider buying through @msinger's web site. He does a TON for the readers of this forum.
Cheers!
Ummm yes upgrading gimbal/cam DOES increase the downlink. Which is the whole reason I did it - the FPV difference is night and day, easily the best money I spent. OP, for some reason some people are super intent on proving that upgrading the gimbal/cam on an Advanced to a Pro doesn't change anything/isn't worth it/doesn't improve FPV/doesn't change Lightbridge/whatever and it's simply not true - I'd do it again in a heartbeat. So upgrade with confidence! You will absolutely love it.
Reactions: Oso and Reed L
Popcorn... Wait for it.. It's coming.
tpren3
