Camera video delay
My Phantom 3 Pro is having 2 to 3 second video delay I have to go in and reset the camera and power off and Power on the controller why is it doing that
Sent from my SAMSUNG-SM-G900A using PhantomPilots mobile app
What kind of mobile device are you using? Did this occur the first time you used your Phantom?
I'm using a S5 Galaxy it did not start when it first got it it's just recently after I had a new camera and replaced and for some reason when I sent back my controller it was probably the case was broke which I've repaired but it was slow like I said 2 or 3 seconds delay but since I started using litchi I have had no problems
anybody are installing a cooler fun in the gimball for PH3 Adv?? i ck that and this is the first problem por the delay video, the temp is overheating
[Quote = "Mako79, de la publicación: 1044740, miembro de: 11292"] ¿Ha intentado hacer un reset frío en el cardán ?? Apagar el fantasma y desenchufe los cables de 2 a Goto el cardán. Espere 30 segundos. A continuación, vuelva a conectarlo a una fuente de encendido.
solución de vídeo de retraso
Si, a pesar 2-6 seg queda entonces puede mirar en el mod almohadilla térmica.
Fantasma 3 Propietarios avanzada con el mal 2 - [! Fijó finalmente] 6 segundos demora de video [/ quote]
Hola mucha muchas gracias, su consejo fue de gran ayuda, repare El problema desarmando el cardán y en la Tarjeta de video GPU puse pasta térmica además de cambiar el thermpad por uno nuevo y la temp cambia a un máximo de 58 grados centrigrados y el video llega en tiempo real.
Reactions: Reed L
jrl
