Camera not level
I took some video today for the first time with the Plus and I noticed that the camera seems to be slightly off level. The It makes the video appear like the horizon is slanted a bit. Any way to fix this in assistant by messing with the camera gains? Is there any way to get the props out of view of the video? I was very impressed with the stability of the video compared to the regular Vision.
Ive seen this on several Vision plus videos, and I often wondered why, it doesn't happen with the standard Vision. :?
Is there a way to calibrate gimble in assistant? Its only a couple of degrees off, not jerky just not quite level.
An IMU calibration using the assistant software should correct the issue. Make sure your Phantom is level while calibrating.
