Camera Modes not changing properly
There have been several that have seen this issue since the latest update. Here is a little example, and a work around. Its basically tied to changing camera modes and it not actually changing. It SOUNDS as if it is, like going from single shot to a 7 shot burst. But its stuck in single shot, but makes 7 shutter noises. Hope this helps!
Camera modes problem
Reactions: Meta4
That explains this new glitch pretty well.
You can tell if your burst mode isn't working because although the camera makes the burst sound, the blue righ around the app shutter button is only there for a fraction of a second and there's no waiting to shoot again.
So, having fully watched the video, this is what I learned from it.
1. If you only use the onscreen shutter button, everything works as expected when choosing any of the shooting modes with any number of selected shots. No surprises.
2. To use the transmitter shutter button reliably, you first have to pre-program it by taking one set of images with the onscreen shutter button in your chosen shooting mode, specifying the number of images a single shutter press with the transmitter shutter button should take.
As long as you do 1. or 2. each time you make any change to your shooting mode, including the number of frames to be taken, everything is Golden!
Since we now have all these new fancy flying modes that fly the aircraft for us, during previously complex manual moves, that leaves your right or left hand temporarily free to use the onscreen shutter button, at least the first time you need to use a new shooting mode or change the number of frames selection.
I imagine DJI will tell you this isn't a bug, but an undocumented feature. Maybe they will fix it anyway, in the next release, so it works as people expect it to...rather than needing to come here to learn how to use it the way they intended it!:rolleyes: Happy shooting!
Reactions: III% Streve
It's a bug. It's worked fine until the latest firmware.
Reactions: bobmyers
Maybe they just changed their mind about how it should operate now...:rolleyes:
Indeed, hopefully they restore the previous functionality, no matter what they call it now! :cool:
jorge sanchez
