Camera adjustment
My camera has been pointed to one side with landing leg in video There is a 1.5mm grub screw that bears on a flat on the pivot shaft had come loose. Refix with a bit of loctite and all good. As I had update notices for AC and camera I decided to do them at the same time Sucessfull apart from when I fired up and had the message home point updated check it on the map .Last time I checked I am in North Queensland Aus and the map shows Berlin Thankfully Litchi knows where I am :)
did you buy loctite from germany?
Or maybe the drone knows something you don't. better practice using it against blitzkriegs. Once on the ground you are unarmed and easy pickings.
Maybe you picked up the GPS satellite that has been sending malaysia airplanes all over the place.
Reactions: Andy-M
DonT
