C1 & c2
Southampton United Kingdom
is there a way I can customise these buttons to work for the gimbal roll adjust?
Would be a easy way to fix tilted horizon fast?
Cheers
Darren
In Litchi, you can set the c1 c2 buttons to specific functions. One of them is Gimbal pitch/yaw. Don't know if that's exactly what you're looking for.
Cheers but no, I'm looking to adjust gimbal roll with them. Would be great if one button adjusted one way and then the opposite button adjusted opposite way.
Reactions: Simzy666
To adjust gimbal roll in DJI GO4 all you have to do is hold down C2 and use the right scroller (shutter adjuster)
Reactions: Erised
The C buttons are programable in GO but the best way is like luke14321 said, hold down C2 and roll the right wheel at the same time.
Reactions: luke14321
Ah perfect I did not know this.
Does it matter if I have the c2 button set to nothing defined ? It will still work?
And I guess the scroll wheel adjusts both ways, left and right ?
Cheers
Cheers
Yep, don't think C2 needs to be set to anything
Here is my configuration:
C1:Camera up/down
C2 Map View/ Camera view
Is this still a valid issue with the P3s? Noticing date of submission and I think I may have this issue also. Second question. Controller. Does this C1, C2 buttons refer to the left hand switch on the P3s box?
,,,,no,,,,p3s not have these 2 buttons on back of remote,,p3s left switch P A F & right switch flight modes,gosh I think that right,
Yip my c1 set to straight down fast,c2 not set, have slowed speed on Gimble so pans nice and slow when using Gimble wheel so no need to hold c2,,this start stop buffer controls cam speed
Don carlos
