brisk winds @ 90 degrees = tilted horizons, right?
(posted to wrong section, should be P4P)
P4P+ newbie; 30+ short BeginMode flights;
shooting stills only;
is drone supposed to correct itself
in brisk winds, say, 15 mph-30mph,
so that horizon remains straight?
And I assume with gusts it is
unrealistic to expect straight
horizons all the time...?
Getting 0.5-2+ percent tilt on windy days...
Reactions: MedicFL1
Rated at 22.3 mph wind resistance tolerance per manual.
To correct horizon push C2 and rotate right Gimbal wheel.
Even that is limited. Heavy winds are a problem, check with UAV Forecast prior to flight.
Thanks.
C2? A button?
Inner back right side on P4P RC? Next to "||" button?
(or is that strictly shutter button?)
Do button & wheel simultaneously?
Can be done flying BeginMode?
Live at beach, winds normal...
Yes, C2 button and right wheel simultaneously, can be done in any flight mode. If your panning in wind moving fast you may also get a gimbal overload, once I overloaded my gimbal to the point it just went limp, got back home and rebooted my craft and all returned to normal.
Thanks.
Am taking still shots only.
P4P+, can't find C2 button.
Is that only on P4?
What is C2 equivalent on P4P+???
That's always fun!!!!!! Freaked me the EFF out the first time it happened....
Thanks.
Is that only on P4?
On the P4 C1 and C2 are under the remote almost directly opposit the sticks. When holding the remote your finger tips can press these, left hand is C1 and right C2. These buttons are also programable for various functions. In GO go to controler menu and you will have the available choices.
akinproplumbing
