Bretts Superpatcher now working
Manchester UK
After reading the thread from @Toomanyplanes about SP and as its part of my modding tool I dug it out and had a look at it and sure enough it fell over due to the busybox file, After fixing that issue I also found that it no longer downloads the standard 01.04.0300 FW for the Mavic Pro and the 01.00.1500 FW for the P4Pv2 due to dead links in the WhichAC command, after much head scratching and with the help of ChatGPT i was able to figure out how to upload the 2 firmwares to Github and then i modified Bretts original CMD file to add a file copy which deletes and copies the 2 files into the super-tools folder, the result is that it now works fine again for all quads.
the modding tool ( a collection of all the mod tools in use, feel free to ask for any others) can be found at the link below, however i cant do it as a standalone as I dont know how to edit the batch file copy/delete command to work in a folder that people may put in different locations, if anyone on here can do it then please let me know as it would be a bonus.
Reactions: DoomMeister
I have worked out how to get SP to work as a standalone program as opposed to being part of the multitool, just download the original files from Bretts repository and then replace the 3 files with the ones in the attached zip file and it should work
the 3 files are
an edited main batch file that does the file copy
the correct busybox,exe
an edited WhichAC.cmd file that has the correct links to the 2 missing FW files
Let me know if you have any issues
Busybox was the first issue I got working but you went beyond that. Very nice! I too saw the two stock firmware files that would not download and got those from Dank Downloader. I found out that Superpatcher only downloads files that you use from the repository BUT it saves them to your local Superpatcher files so you don't need to download them again. I went to the .cmd file for "WhichAC" (I think...) and got all those files and saved them to the local files in Superpatcher. That way if something happens to the repository at Github I already have them stored locally. I also modified the "DJI_Super-patcherV2.02.cmd" start file so you can bypass the program's need to be on the internet and just use the local files stored on the PC. I noticed BRETT had a comment in his code that if you did not have internet "would you like to proceed anyway?". Maybe he was planning on that at some point? Superpatcher does not allow going beyond the start screen without the internet (from what I have seen). Its great its working again!
Reactions: crash1sttime
