Bluetooth connection slow
Discussion in 'DJI Ground Station' started by VoicOfReason, Oct 28, 2014.
  1. VoicOfReason
    So, I just hooked up my ground station to Phantom 2 and iPad Retina Mini. I can connect via Bluetooth from ground portion to iPad but it takes about 3 minutes before it recognizes the bluetooth connection. Is this normal? Any suggestions? Is this because you can only connect to bluetooth once satellites are locked in? I was doing all of this indoors.
  2. VoicOfReason
    Actually may take up to 5 minutes. Is this normal?
  3. job2310
    Bristol, England
    Mine is fairly instant using my iPad Air.
  4. VoicOfReason
    I flashed the firmware several more times and then tried again and it's working perfectly now.
  5. job2310
    Bristol, England
    *thumbs up*
  6. RoyceSims
    Re: Bluetooth connection
    Question. I have a Dell Laptop that has bluetooth in it , i wondering if it will connect to the ground station like the ipad .
  7. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    Just use the USB cable. It powers it and talks to it via the special USB cable it comes with. Not sure if the PC app utilizes bluetooth or not.
Similar Threads - Bluetooth connection slow Forum Date
iPad Mini Bluetooth - PS3 Connection Issue Standard/4k Discussion May 12, 2016
Bluetooth GPS for ipad? Pro/Adv Discussion Dec 16, 2016
Litchi, iOS and Bluetooth = crash? Software Nov 16, 2016
Has anyone used Bluetooth/Gps keyfinders on their quadcopters to track? General Discussion Oct 25, 2016
Bluetooth Standard/4k Discussion Oct 14, 2016
