Binding tx to quad. question
Raymore Missouri
I have a Phantom 1. I am getting another. Same version. Can I use either transmitter with either quad or were they bound at factory?
or do they bind at power up
Bound at factory, and though you can re-bind them, from what I've seen, it requires taking the shell off to hit the little button. On the Phantom 2's, it's an underside lit button.
You will find Phantom 1 instructions here:
http://wiki.dji.com/en/index.php/Phanto ... d_Receiver
With little modification, a small pushrod could be installed to make binding easier (without having to take the cover off).
I think you should be able to access it through the battery door. Just look for the little red led, and the bind button should be right next to it.
Don carlos
