[/quote]SeanAxiom said:SeanAxiom said:We did it this afternoon, turned the compass for about 17' CW, it worked like a charm! P2 now hovers very steady with a small or zero drifting, moves forward and backward on a pretty straight line. Will do some fine tuning tomorrow.
landonkk said:SeanAxiom said:SeanAxiom said:We did it this afternoon, turned the compass for about 17' CW, it worked like a charm! P2 now hovers very steady with a small or zero drifting, moves forward and backward on a pretty straight line. Will do some fine tuning tomorrow.
Xrover said:Is everyone that is testing calibrating their compass in the same manner?
ie. Rotating it on it's axis rather then holding out in front of you and rotating your body.
It appears to me that depending on how I do a compass calibration and the speed at which I do it results in slightly different behavior on the flights. It's hard to tell which method and speed of the calibration procedure yields the best performance on the first flight. I think the P2 behaves differently on the first flight as the IMU might still be warming up. I have 5 batteries and have noticed that if I fly with a short amount of time in between flights, the P2 fly's a little better each time. Not substantially better but enough that i can feel a difference.
BenDronePilot said:With a regular DJI quad you would move the GPS puck to the proper magnetic declination. I wonder if anyone has tried moving the Phantoms puck which is stuck to the upper body shell to compensate.
John Shaw said:I do think the Course Lock Offset is the most dramatic effect and may lead to easier analysis as it does not appear to be dynamic. It seems once the Course is set it doesn't change like the JHook does. I assume if you reset the course periodically you would see the offset decrease each time it was reset. I have been planning to test this but our weather has not been very cooperative.
My declination is +17
cruiser607 said:DJI was obviously able to reproduce the issue with my data from NZ.
They asked for a retest in ATTI mode. Hopefully I can deliver this data this week.
They already have these results.ianwood said:Please do the test I outlined above as well. They want both tests.
