Best way to get smooth shots *onsite* for the first time?
I've had many of the same issues too when I got my phantom 4.... to get really smooth transitions and flybys you need to
1. Lengthen the joysticks for finer control
2. Detune the control inputs so the greatest increase is nearer the end of travel ( under controller menu)
3. Set gimbal speed around 30%
4. Use course lock a lot
5. Practice the pan, tilt and timing of the shot more than once .... before you turn the camera on
6. Don't turn the camera off till well after you think you got it right. Most say at least 10 sec
I'm still learning litchi so dji go does quite well for me ... so far I'm only using litchi for preplanned routes
Why not just let he camera record for the whole flight?
Unless your trying to save edit suite time paying for someone to do your post production practice runs prior to committing to recoding a take make little sense.
I'd rather have excess footage to play with in the edit. Having to think about stopping and starting recording while focussing on your stick movements and gimble pitch adds complexity. Not to mention how easy it is to forget to record.
Reactions: eneilsen
I tend to shoot 4K on those special shots so i find it just takes too much memory to upload to my computer and the I have to go load gigabytes and search for the shot instead of just dealing with the 1-2 gigs I want. When you do 10-12 shots in 20 min it's just easier. I use 32gig chips
With long recordings the 4GB split (and AFAIK a few missed frames) might then occur in an unwanted spot.
(FAT32 file system limits file size max 4GB. exFAT allows larger files but unfortunately the Phantom still splits the videos at 4GB.)
Reactions: Mako79
Correct. I'd rather a few dropped frames than no recording at all, started late, finished early or jerky flying while dicking around with the record button.
When you say lengthen joystick do you mean physically?
+1
If you are flying manual, decrease the expo setting to 0.2 on yaw settings.
If you have Litchi - use FOCUS mode. If its a moving target, use Litchi Focus with a Leashed device.
Michello
