Was wondering what is the largest capacity battery that will fit in the Phantom FC40 w/ the extended battery door? I understand the largest you can put in with the stock door is 2700 mAh.
Re: Best LiPo for longest flight WITH aftermarket battery do
the 4000 fits just fine, little bit of cutting its a great fit. small cutout on the side. I drilled a hole on the side of the body, ran the power lead through the body, run the battery lead out the side of door, put battery in body , close door, ready to go , no more tucking wires in that small space, a lot easer this way, I think
With the Trinity 4Ah, my stock FC40 gets 14-23min till power down using dji OEM 9443s, and original camera mounted.
The 3Ah gives 11-16min flights.
In general I get 3.5-5min of flight per Ah of battery, depending on how demanding the flight is.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
