Best LiPo for longest flight WITH aftermarket battery door?
Discussion in 'Phantom FC40 Discussion' started by maximusa, Sep 3, 2014.
  1. maximusa
    Was wondering what is the largest capacity battery that will fit in the Phantom FC40 w/ the extended battery door? I understand the largest you can put in with the stock door is 2700 mAh.
  2. Mandrake
    Melbourne , Australia
    Re: Best LiPo for longest flight WITH aftermarket battery do
    That's it at the moment..
    Saw a 3300 on ban good.com but its a bit too wide and heavy any gain would be offset by the extra weight !!
  3. pert
    Bermuda
    the 4000 fits just fine, little bit of cutting its a great fit. small cutout on the side. I drilled a hole on the side of the body, ran the power lead through the body, run the battery lead out the side of door, put battery in body , close door, ready to go , no more tucking wires in that small space, a lot easer this way, I think
  4. Mandrake
    I now have a hole in FC40 side and a battery carrier at rear..it balances the camera and gimbal quite nicely..
  5. teccer
    SW UK
    this is the lipo I use, 3000mAh it will go in wire first on my V1.1.1 but I didn't like to keep bending the wires so now I've cut a small hole either side of the door and this lipo fits so easy and you can close the door the connect the wires from the outside whenever your ready to fly. it only weighs 205 gm so no great loss of flight time, my phantom auw is 1235gms and with this lipo I can get at least 10 minutes flight
    http://www.ebay.co.uk/itm/191593163428?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    #5 teccer, Aug 21, 2015
  6. fdmontgomery
    With the Trinity 4Ah, my stock FC40 gets 14-23min till power down using dji OEM 9443s, and original camera mounted.
    The 3Ah gives 11-16min flights.
    In general I get 3.5-5min of flight per Ah of battery, depending on how demanding the flight is.
  7. Bob Dennis
    Hi I use a 2900mAH battery with the standard door.
  8. Ti22
    San Diego
    I just add an external bracket on the rear - running 2 stock 2.2Ah batteries.
  9. dtitus6297
    Black Magic 3000mah fit in with stock door. Nice and cheap batteries as long as they are respected they will last
    Sent from my SM-G900V using Tapatalk
    magish01 likes this.
Similar Threads - Best LiPo longest Forum Date
Best Practice for first Lipo charge Phantom 4 Discussion Mar 15, 2016
Advice on how to best keep Lipo Batteries Please Phantom 4 Discussion Mar 2, 2016
Best care for LIPO battery Pro/Adv Discussion Jun 6, 2015
Best Way To Discharge LiPO Batteries--Your Recommendation Phantom 2 Help Mar 20, 2015
Best lipo without mods Phantom FC40 Discussion Sep 2, 2014
