Best iPhone Case for Mavic Pro controller fit?
What's the best iPhone case for this in terms of fit? I see it has both a built in wire and another port for any other wires you want so it isn't the most important thing to get the perfect case but I'd like to use the built in ne. I currently use the Lifeproof and wonder what the fit would be like or if I need a new case.
The remote controller mount can only hold devices that are up to 6.29 inches tall and 0.25-0.33 inches thick (including the case).
Since the iphone itself is the dimensions below, what you're saying is that it won't fit an iphone with any case?
H 158.1 mm (6.22 in) W 77.8 mm (3.06 in) D 7.1 mm (0.28 in) (inc. lens, 7.67 mm, 0.302 in
It'll only fit if you have a thin case.
There are probably a hundred slim cases like this one available.
I've used this on my iPhone 6 Plus for the last two years. Should just fit the measurements for the Mavic controller. Provides good protection for edges and case back. If not, you're only out a couple of bucks.
EstebanP4+
