Phantom 2 having 5200mAh battery and Naza v2, is there anything else that makes it a better quad than v1?
Miika said:Am I right by saying that ALL the Naza V1 controllers are red and ALL Naza V2 controllers are yellow? So I coud look into the Phantom before buying it and see if it has V1 or V2?
.Quadzilla. said:I f you are buying right now the P2 is a nobrainer despite the higher battery costs. The package price with a Zenmuse is ridiculous if you consider the original price of the Zenmuse back in the V1 days.
rilot said:Remember, with the V1 you need to buy the upgrade board too and install it which means soldering.
Just get the P2. I changed from a P1 to a P2 and it's just... better. CAN port for easy iOSD connection etc.
OI Photography said:Yep, looks like you have a NAZA v2 with the original board (although it looks like it was trimmed a bit) and the PMU.
That taped-off cable you were asking about does look like it's the original power lead from the board to the NAZA that was replaced by the one from the PMU. Which is probably why they removed the plug and taped it off, so it couldn't accidentally get plugged in while the PMU was also connected.
