Battery
Hi, I'm just wondering if it is OK after you drain the battery down about half way and charge it up again or if you should drain properly.
These batteries have no memory effect. Draining the battery further is not necessary.
Long time storage voltage is approx 80% if you're not going to use it for a while.
If you're not going to use for a couple of weeks level at 50%. There is no need it up again and drain all over again.
