Battery storage for p3
Is there anything that needs to be done to preserve the battery for long term storage for a year or more? I have to deploy in June so it's going to be put away for a while. Just not quite sure what needs to be done to condition it.
Besides the usual room temp, dry, dark place I think set them at about 50%. And thanks for your service.
I have a hard case that I modified to keep my bird in so it will not be disturbed during my time away. The 50 percent mark your referring to, is that in the app under the battery settings.
What version of batteries do you have - are they the latest "smart batteries" or the older style like in the P2's. The "smart batteries" will discharge themselves after 10 days of no usage unless you have set them up to discharge sooner than 10 days via the DJI Go App.
Nonetheless, you should discharge your battery down to 3.6v-3.8v per cell for safe storage until you are ready to use the battery again.
Should be stored in a LiPo "safe" bag or even an ammo box away from any kind of heat source.
Store them in a cool (average temp) environment if possible.
Don't kid yourself - and good on you for asking......LiPo's are a huge fire risk of not stored properly - swings in temp for example are not a good thing for the LiPo's.
EDIT: LiPo's don't become damaged or lose their re-charging ability after long term storage - but after a year or so of storage they will lose around 4%-5% of their efficiency .
Since he posted in the P3 forum Ill assume hes talking about P3 batteries. Do not discharge to 50% before storage. Set the discharge time to be 4 days in the app and make sure your battery has the latest firmware. Let the battery self discharge to storage level. This will discharge each cell to storage level. Thats the beauty of the smart battery. Discharging it yourself is trickier than you think to get all cells good for storage (and we dont have cell taps on the battery to discharge per cell).
Yes the battery in question is in fact the latest smart battery I assume. My copter is one one the 799 professional eBay deals. I'm not set to deploy till June but I just couldn't hold out on getting one after I saw what the price was.
Agree - worth asking however. The smart battery will take care of the proper discharge after the allotted time has passed - like you said and is the proper way for discharging for sure.
Just be sure to store in a LiPo safety bag or box - that's important.
We had a LiPo for an analyzer explode inside a shop metal container that was placed there for safety.
Unfortunately and forgetfully - over time the storage box was moved a couple of times and the last time it was exposed to direct sunlight for half the day - hence the "boom".
If you don't mind me asking - where are you being deployed to?
Auto discharge can be set to commence after 1 day now in the DJI Go app.
I am due to deploy to Kuwait and make runs into Iraq. With that said I highly doubt that will be where I end up because they don't tell you, well atleast they were not to truthful on my last deployment. It's the whole operational security thing I guess.
I understand that the ammo box won't prevent a lipo fire but rather, contain it in case something does go terribly wrong. But my question is; should there be a small vent hole somewhere on the box to release the pressure if a fire were to happen? If it remains sealed during a fire and pressure builds, wouldn't the ammo box (potentially) explode?
My batteries have been stored in an ammo box for the majority of the winter and after seeing examples of lipo fires on YouTube, I've wondered about adding a small vent.
Put away at full charge or while on charge are the most dangerous conditions.
I have seen the you tube vids also. Drive a nail into a cell or apply a significant over voltage to the pack and you will get spectacular results. Other circumstances a puffed pack is all is likely. The ammo box as is probably enough.
A year is an awfully long time. At first I liked sonof40's response (with a lipo bag) but I too wonder what happens to the battery as it sits for months unused. Does it slowly lose its charge? I don't know. But I'd imagine it would. So maybe storing it closer to 60% is best.
Reactions: curiosity
4S LiPo batteries should be put, for long term storage, at 3.80-3.85 (mostly 3.85 Volts per cell).
Just put them to auto discharge, and they should discharge to long term storage level.
My main concern was the degrading of the battery over time. My wife will remain at home so I had thought about getting her to top it off every month but I didn't know if that would actually do more harm than good. I would guess that it would add cycles to the battery therefore lowering its effectiveness.
Just put them at factory storage level, and don't worry. That is the best you can do to store them long term. Also use a lipo bag, or ammo case as said before.
That's what I'll do, thanks
jorge sanchez
