Battery issue....
One of my batteries is flashing this light constantly. It shows charges, however isn't.
Any recommendations?
The green light on the port the battery is connected to suggests the charger thinks the battery is charged fully while the yellow light opposite (no battery connected) indicates not charging (it should be solid red to indicate no battery connected). I would suspect the charger might have an issue. Connect the battery direct to the charge lead in the first instance. If you have no joy turn it in before connecting.
Tried connecting charger direct, and get the same result.
Dud battery?
According to the manual, this LED3 light blinking twice per second indicates an 'over charge detection' and if its blinking three times per second indicates an 'over-voltage charger detection'
In the first situation i would try to discharge the battery down
In the second, try the battery on a normal (single) charger, as this would indicate there is an issue with your multi charger hub
src72
