Batteries won't charge!!!
So I get home, try to charge the depleted batts....no go! The LED on the brick is green (getting power) but none of that is getting to the batts. HELP Any ideas?
I believe if the battery is over 90% or so charge - you have to turn it (the battery) on before you plug it into the charger - below that point the battery will turn itself on when you plug it into the charger.
I was ill for 9 months and my 3 Vision 2 batteries sat in the carrying case for all that time and now are totally discharged and WILL NOT CHARGE. There is one green dot present and no matter how long I leave them in the charger nothing further happens. They do not work in my phantom. At most each was recharged in the past about 8 times. Any thoughts, or are these paper weights. Any help would be appreciated.
Yes - did all the usual things to start the batteries, but no response. Thanks for your response though.
No problem and not sure what else to tell ya . Have never had your issue but sure if the right person see's this they can help ya . I can't believe you can't wake them up some way .
Glad ya not ill now though and can work on this ! Good luck ! :)
Maybe try to leave on charger for some time: if battery is hard discharged they can show charging only after some time.
The battery needs a rest period after flight to cool down. Normally 30 minutes then it should charge. Give it a try then.
If neither battery will charge, my guess is the problem is with the charger. Maybe put a meter to it to see if it is putting out the correct amount of juice? Maybe try cleaning all of the contacts?
I was sent a new charger by the company that sold me the batteries. It did not help. Thanks, though.
Okay.. but maybe Prylar Bek's charger is bad.
TK-62119
