Batteries won't charge!!!
Discussion in 'Phantom 2 Vision + Discussion' started by Prylar Bek, Nov 29, 2014.
  1. Prylar Bek
    So I get home, try to charge the depleted batts....no go! The LED on the brick is green (getting power) but none of that is getting to the batts. HELP Any ideas?
  2. Meta4
    Meta4 Moderator
    Staff Member
    You normally don't have to unless the battery is up around 90% but you could try turning it on and charging??
  3. Prylar Bek
    Yea did that And now the brick LED is red Is that 'normal'
  4. bergenfelter
    I believe if the battery is over 90% or so charge - you have to turn it (the battery) on before you plug it into the charger - below that point the battery will turn itself on when you plug it into the charger.
  5. Prylar Bek
    True All is good
  6. tanstafl
    Agoura Hills, Ca
    I was ill for 9 months and my 3 Vision 2 batteries sat in the carrying case for all that time and now are totally discharged and WILL NOT CHARGE. There is one green dot present and no matter how long I leave them in the charger nothing further happens. They do not work in my phantom. At most each was recharged in the past about 8 times. Any thoughts, or are these paper weights. Any help would be appreciated.
  7. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    You did push the button twice to cut the battery on and then plug it up right ?
  8. tanstafl
    Agoura Hills, Ca
    Yes - did all the usual things to start the batteries, but no response. Thanks for your response though.
  9. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    No problem and not sure what else to tell ya . Have never had your issue but sure if the right person see's this they can help ya . I can't believe you can't wake them up some way .
    Glad ya not ill now though and can work on this ! Good luck ! :)
  10. Nerius
    Lithuania
    Maybe try to leave on charger for some time: if battery is hard discharged they can show charging only after some time.
  11. RoyVa
    Virginia
    The battery needs a rest period after flight to cool down. Normally 30 minutes then it should charge. Give it a try then.
  12. MapMaker53
    Long Island, NY
    If neither battery will charge, my guess is the problem is with the charger. Maybe put a meter to it to see if it is putting out the correct amount of juice? Maybe try cleaning all of the contacts?
  13. tanstafl
    Agoura Hills, Ca
    I was sent a new charger by the company that sold me the batteries. It did not help. Thanks, though.
  14. MapMaker53
    Long Island, NY
    Okay.. but maybe Prylar Bek's charger is bad.
    #14 MapMaker53, Jun 7, 2015
Similar Threads - Batteries won't charge Forum Date
Advanced Batteries won't self discharge. Phantom 3 Help Mar 27, 2016
Batteries won't charge General Discussion Nov 29, 2014
Batteries Won't Connect to Drone Phantom 2 Vision Discussion Jun 3, 2016
New batteries won't work Phantom 2 Vision + Help Dec 19, 2014
Phantom 4 Batteries Classifieds Yesterday at 7:09 PM
