Batery problem ???
L.A.
My last flight was a little strange , I went in flight with a battery of 96% and at a distance of 3,626 meters with 60% of the battery , the battery has got red color Low power , going home after all 06m 42s of flight , after cancell go home battery is again returned to green log indicates that the battery is ok
I have p3p batery 17 time charge
Check the individual cell voltages on your Go App and see if they are close to the same. Ideally you would check them under load (during flight) to see if you have a possible single cell dropping out (going bad). I think you can go to that screen during flight?.... I have never tried it but that is the first thing I'd check before doing another flight very far away...
Thank you for your response
it was just a failsafe mode ,
the wind was blowing in front of the drone , at that distance drone thought it was time to go home , and when he turned and made the 100m with the wind at his back he realized that the rate at which it passes to be enough to get home , than again turn green battery !!!!
