- Joined
- Nov 21, 2015
- Messages
- 147
- Reaction score
- 48
- Age
- 63
I have a question. On most mulit-engine birds the engines are numbered. I, 2, 3, etc... I saw a reference to engine positioning and numbers, but no definition. Usually it is Pilot inside left is #1, Pilot inside right is #2, with outside left as #3, and outside right #4. Is there a sequence to the P3? and do you know what it is? Thanks in advance.
got mine out to over 7000 feet.
Check sensors for true wind vs. apparent wind measurement accuracy
I'm interested in what your mod looks like. I have a cheap windsurfer from Amazon and I went 6500 and still had video, but got nervous and came home.Only 5400 feet, but I have a lot of upside in my bag of tricks. My goal is to beat Dirk (8800 feet).
Yeah the windsurfer is pretty cool. I made one. I tested it with an EMF meter and it makes quite a difference. Right now it's attached to my router![]()
Wow. This is the first I've ever heard of lubing the motor bearings....
On my Phantom 2 Vision Plus, I use synthetic gun oil after every 10 flights on the motor bearings. Haven't had problems.
My P3A is too new and the bearings are much larger, so it'll take a long while before I lube them, if ever.
Thanks, I have made a note of that. Will keep it that way until I can verify that the P# is the same or that it is an industry standard.FWIW: With the Naza based FC, on an 'X' quad, the motor numbers are: Right front is #1, then CCW from there ending with Right rear #4.
I have a P2v and this is the P3 forum, so I'm not sure what benefit my mod is to y'all. The stock distance on the P2V is only 500 meters.
The placebo effect is pretty strong. Typically you get responses in the 10 - 40% range. That would give you quite a bit more performance.This is one of those Placebo effects. They're sealed bearings.
Forget the blinker fluid. The muffler bearing on my p3 just went"kapoot"!!!! Any idea on how to get the framis off the wiggle pin? Any help would be great.
I think it comes in a 3 bottle set. One each of Luceferin and Luciferinase, and third with red dye. Drain both pairs of tanks, refill with the mix of the two, and add a drop of dye to the two front tanks and be sure all four tank valves are open to admit oxygen.Replace the blinker fluid every 300 miles
And be sure to top off the prop wash before flying!Dang!!! There's Blinker Fluid Too??? Lmao!!!
I'm never going to get to fly!!![]()
Oh yeah, that reminds me - whenever I do a deep discharge, I try to clean the contacts inside the battery and also the posts in the craft. I apply Deoxit which was recommended in another thread.
Left Handed Bacon Stretcher should also be used on landing gear.Forget the blinker fluid. The muffler bearing on my p3 just went"kapoot"!!!! Any idea on how to get the framis off the wiggle pin? Any help would be great.
