havasuphoto said:No.
Also, the self-tightening props only work on the Phantom ver. 1.1.1, and the Phantom 2 and vision. If you have an older Phantom-all silver nuts-you're outta luck, you can't use these self-tightening props.
You may be right. IF you have 2 silver nuts and 2 black nuts, then you have the cross-threaded or reverse thread engines-and could use the self-tightening props. IF, all 4 of your prop nuts are silver, OR, all 4 of your prop nuts tighten when turned to the right-you can't use them.OI Photography said:havasuphoto said:No.
I have a 1.2 and the self-tightening props work on my stock motors (CW+CCW threaded). I think it's just the original 1.1 (not 1.1.1) Phantoms that don't have the cross-threaded motors/nuts.
havasuphoto said:You may be right. IF you have 2 silver nuts and 2 black nuts, then you have the cross-threaded or reverse thread engines-and could use the self-tightening props. IF, all 4 of your prop nuts are silver, OR, all 4 of your prop nuts tighten when turned to the right-you can't use them.OI Photography said:havasuphoto said:No.
