balance self tightening blades
Discussion in 'General Discussion' started by sprung, Dec 28, 2013.
  1. sprung
    are the silver and black caps on the self tightening blades removable?
  2. havasuphoto
    Lake Havasu, AZ
    No.
    Also, the self-tightening props only work on the Phantom ver. 1.1.1, and the Phantom 2 and vision. If you have an older Phantom-all silver nuts-you're outta luck, you can't use these self-tightening props.
  3. reALIGNed
    S.E. Wisconsin
    I saw a video of a guy that balanced his self tightening props. I'll go look for it and post back.
  4. reALIGNed
    S.E. Wisconsin
  5. OI Photography
    Clarksville, TN
    I have a 1.2 and the self-tightening props work on my stock motors (CW+CCW threaded). I think it's just the original 1.1 (not 1.1.1) Phantoms that don't have the cross-threaded motors/nuts.
  6. sprung
    thanks, the video helped
  7. havasuphoto
    Lake Havasu, AZ
    You may be right. IF you have 2 silver nuts and 2 black nuts, then you have the cross-threaded or reverse thread engines-and could use the self-tightening props. IF, all 4 of your prop nuts are silver, OR, all 4 of your prop nuts tighten when turned to the right-you can't use them.
  8. OI Photography
    Clarksville, TN
    Right, that's always the best way to tell for sure.
Similar Threads - balance self tightening Forum Date
Prop balancer for Self tightening props? And help solve airframe vibration problem. General Discussion Apr 10, 2015
DJI Phantom Balance Rod for Balancing Self-Tightening Props Phantom FC40 Discussion Feb 6, 2015
Balancer Rod for self tightening props Phantom 2 Vision Discussion Feb 25, 2014
How Balance self tightening Props General Discussion Feb 16, 2014
DJI Self Tightening Prop Balance Rods Classifieds Jan 25, 2014
