Nice video. You can reduce the prop wash effects by, 1. Flying slower, 2. using lower ISO
I understand how using a lower ISO would affect a regular camera. Images with rapid motion would be blurred.
How exactly would that eliminate prop visibility, which are already going too fast for the frame rate to capture?
I was thinking that flying slower would be far better, but I liked the general appearance of the video at the speed that it was recorded. How practical is it for video editing software to take a slow recording and speed up by a certain percentage? (I'm not at all skilled in video editing)
EDIT: it also occurs to me that the operator needed to fly fast so as to cover the desired terrain and still have enough battery to complete his circuit. Life is full of compromises; we seldom get everything we want.
Hvala tudi vam, lep pozdrav!Andy you did an excellent video. The props visibility didn’t bother me. If it was made intentional to add to the affect that was fine. I love the timing of the tree color. It was a great mix of color. The color was done beautifully and not overly bright. It gave me a pleasant feeling watching the scenery go by. The mix of trees, rocks, green valley and sky gave such contrast. I always like that, in seeing the feeling or a texture of the area. Your creativity near the end with such subtle changes from flying to driving and the nice stills made a good presentation. I hope your wife enjoyed the beautiful day with you?
Hvala vam!
Don't know why you think about high ISO. There was enough light for normal (low) ISO. Must check it out.There are times when using a higher ISO that you actually catch "the reflection" off the props instead of the props themselves (experience)
I used to have a similar problem when I had a P2 with a Gopro that had a much wider field of view than current Phantom cameras. When flying into the sun, the props would cause a shadow as they cut through the sun light. I made a sun shade out of a plastic cup. Think of it as an elipse cut in half, which I velcroed to the camera. I know there are sunshades you can buy.Thanks for the comments!
Yes, I could fly slower but it was not an extreme speed anyway. Usually at such speed traces of propellers have not been seen. I think this appeared because the props were in an exact direction to the sun and make very bright reflections into the camera. However that sequence with props in a visible angle is speed up twice time so the real speed was slower.
Great video, I love these autumn shots..This was filmed few days ago and the colours were just right.
