Pull_Up said:
For my Flytrex board I mount it using 3M Command picture hanging strips.
That's what I plan to use to attach mine. I was going to use Velcro, but the Command strips have the advantage of being completely removable without leaving behind any gummy residue. The disadvantage is, of course, that I'll have to use a new set of strips if I remove and replace the tracker (which I might do if I want to use it in one of my rockets).
The strips are rated to hold about 1 pound each. I'll use two strips. The tracker weighs less than ounces. So, the strips should secure the tracker against up to more than 16Gs. Of course, they are designed to hold things vertically on walls, not hanging horizontally, so they might fail at a lower acceleration. But, if my P2V experiences anywhere near that many Gs, it'll probably end up on the ground beside the tracker.
-- Roger
