Asus Nexus 7 2013 Won't Connect to Go App
My new P3P working just fine with my iPhone but no luck getting it to connect to my Nexus 7 2013. Tablet seems to work with Litchi though.
Any ideas? Anyone else with this issue?
Tablet is up to date with latest firmware revision.
Thanks,
Tom
That is weird. I just purchased a used one and just completely wiped the device when I got it. I updated the OS to the latest version, which I think is called Marshmallow. Once there the first thing I did was install the DJI GO app. I thought I might have to go in to developer mode and enable the USB as well as some other tips I've seen online, but I didn't need to. It just connected right away.
The problem might be with the USB connection. If you connect the Nexus to a computer using the same USB cable, can you read and write files?
Tried a couple different cables, but I'll double check.
Thanks
....and never mind. It's working now - no idea what I did to fix it:(
Thanks for your help all!
Tom
Michello
